Saltar al contenido principal
LG Aristo Screen Replacement
Qué necesitas
  1. LG Aristo Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Turn off the device and make sure you are working on a flat, lit surface.
  2. LG Aristo Screen Replacement: paso 2, imagen 1 de 2 LG Aristo Screen Replacement: paso 2, imagen 2 de 2
    • Use an iFixit opening tool to pry off the back case.
  3. LG Aristo Screen Replacement: paso 3, imagen 1 de 3 LG Aristo Screen Replacement: paso 3, imagen 2 de 3 LG Aristo Screen Replacement: paso 3, imagen 3 de 3
    • Remove the SD and SIM cards by sliding the cards out with your finger.
  4. LG Aristo Screen Replacement: paso 4, imagen 1 de 3 LG Aristo Screen Replacement: paso 4, imagen 2 de 3 LG Aristo Screen Replacement: paso 4, imagen 3 de 3
    • Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
  5. LG Aristo Screen Replacement: paso 5, imagen 1 de 2 LG Aristo Screen Replacement: paso 5, imagen 2 de 2
    • Remove the ten screws from the midframe with a Phillips #000 screwdriver.
  6. LG Aristo Screen Replacement: paso 6, imagen 1 de 2 LG Aristo Screen Replacement: paso 6, imagen 2 de 2
    • Pry up on the screen with a plastic opening tool.
    • Try to avoid using a metal spudger as shown in the images as it has the possibility to damage the screen.
  7. LG Aristo Screen Replacement: paso 7, imagen 1 de 2 LG Aristo Screen Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Detach the cables from the press fit connectors.
    • There are four connectors in total, they consist of two on the cameras, one on the ear jack, and the one attached to the motherboard.
    • You can lift them up with you finger or you can use tweezers (optional).
  8. LG Aristo Screen Replacement: paso 8, imagen 1 de 2 LG Aristo Screen Replacement: paso 8, imagen 2 de 2
    • Gently remove the motherboard.
  9. LG Aristo Screen Replacement: paso 9, imagen 1 de 1
    • Replace the screen.
Conclusión
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
2 personas más completaron esta guía.
Equipo
Gateway, Team S1-G5, Saknee Fall 2019 Miembro de Gateway, Team S1-G5, Saknee Fall 2019
GCC-SAKNEE-F19S1G5
4 Miembros
1 Guía escrita
Un comentario
Do i need Loca Glue to replace the outer Glass?
chuck - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 1,336
