Saltar al contenido principal
LG Aristo MS210 Front and Rear Camera Replacement
Qué necesitas
  1. LG Aristo MS210 Front and Rear Camera Replacement, Battery: paso 1, imagen 1 de 3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: paso 1, imagen 2 de 3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Front and Rear Camera Replacement: paso 2, imagen 1 de 2 LG Aristo MS210 Front and Rear Camera Replacement: paso 2, imagen 2 de 2
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Front and Rear Camera Replacement, Command Button: paso 3, imagen 1 de 3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: paso 3, imagen 2 de 3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: paso 3, imagen 3 de 3
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Front and Rear Camera Replacement: paso 4, imagen 1 de 3 LG Aristo MS210 Front and Rear Camera Replacement: paso 4, imagen 2 de 3 LG Aristo MS210 Front and Rear Camera Replacement: paso 4, imagen 3 de 3
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
  5. LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: paso 5, imagen 1 de 3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: paso 5, imagen 2 de 3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: paso 5, imagen 3 de 3
    • Use the spudger to disconnect the ZIF connector securing the front-facing camera.
  6. LG Aristo MS210 Front and Rear Camera Replacement: paso 6, imagen 1 de 3 LG Aristo MS210 Front and Rear Camera Replacement: paso 6, imagen 2 de 3 LG Aristo MS210 Front and Rear Camera Replacement: paso 6, imagen 3 de 3
    • Use the spudger disconnect the ZIF connector securing the back-facing camera.
  7. LG Aristo MS210 Front and Rear Camera Replacement: paso 7, imagen 1 de 1
    • Remove both the front and back facing cameras.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 159
