Saltar al contenido principal
LG Aristo MS210 Screen Replacement
Qué necesitas
  1. LG Aristo MS210  Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Identify the problem.
  2. LG Aristo MS210  Screen Replacement: paso 2, imagen 1 de 1
    • Remove back plating to expose the battery, sim card, and SD card (if applicable)
  3. LG Aristo MS210  Screen Replacement: paso 3, imagen 1 de 2 LG Aristo MS210  Screen Replacement: paso 3, imagen 2 de 2
    • Remove the battery.
    • Remove the Sim Card
    • If applicable remove the SD card.
  4. LG Aristo MS210  Screen Replacement: paso 4, imagen 1 de 1
    • Remove the ten screws with a Phillips #00 screwdriver.
  5. LG Aristo MS210  Screen Replacement: paso 5, imagen 1 de 1
    • Use finger nail or wedge to gently remove dust cover, and reveal the motherboard.
  6. LG Aristo MS210  Screen Replacement: paso 6, imagen 1 de 2 LG Aristo MS210  Screen Replacement: paso 6, imagen 2 de 2
    • Detach the bottom cable from the socket.
    • Detach the cable from the socket.
    • Detach and move the cable out of the housing.
  7. LG Aristo MS210  Screen Replacement: paso 7, imagen 1 de 3 LG Aristo MS210  Screen Replacement: paso 7, imagen 2 de 3 LG Aristo MS210  Screen Replacement: paso 7, imagen 3 de 3
    • Remove the motherboard.
    • Remove the front facing camera (top)
    • Remove the audio jack (bottom)
  8. LG Aristo MS210  Screen Replacement: paso 8, imagen 1 de 1
    • Place components onto new screen/ digitizer.
  9. LG Aristo MS210  Screen Replacement: paso 9, imagen 1 de 3 LG Aristo MS210  Screen Replacement: paso 9, imagen 2 de 3 LG Aristo MS210  Screen Replacement: paso 9, imagen 3 de 3
    • Reattach back plating.
    • Use mini screwdriver to firmly attach back plating (10) screws.
    • Reattach insert SD card, Sim card, and battery.
    • Reattach back cover.
  10. LG Aristo MS210  Screen Replacement: paso 10, imagen 1 de 1
    • Power on mobile device and make sure everything works properly.
Conclusión
17 personas más completaron esta guía.
10 comentarios
Does the charging port can be replaced?
Mandy - Contestar
What if my touch screen doesn't work after replacement? I can see start up screen. It just doesn't respond to my touch. Please help!! Thanks
Athena - Contestar
4 Possible answers to this:
1. The digitizer is bad - this is uncommon but not unheard of. Roughly %5 of the screens my shop gets in are bad. Most distributors accept returns on defective parts.
2. The digitizer isn’t plugged in to the board
3. The digitizer port on the motherboard is damaged - this can be tested by trying a known good screen.
4. Software issues. This is most common in iPhones, in my experience. So far as I understand, parts can have hardware identifiers similar to a MAC address. Suddenly changing the hardware can “confuse” the software. You can try a force reset or resetting the phone.
James Heinrich -
reconnect the motherboard and make sure its properly replaced
Travis Lasta - Contestar
I guess this is different than older phones where the digitizer and lcd were separate and when you cracked it you could just buy a new digitizer and replace it without having to buy the lcd with the digitizer.? am I correct in this fact because I see that you can buy the black or white Screen replacement with the lg logo without having to buy the lcd is the screen replacement just like a glass protector for the digitizer and lcd? Like a built in glass screen protector that you would normally add on to stop scratches and a cracked screen or is the screen replacement the digitizer like say the lg optimus f60 and the lg motion where the outer screen with the lg logo and the black part of the screen were part of the digitizer?
Steve Hill - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 41
Todo El Tiempo: 16,618
