Saltar al contenido principal
LG A275 Vibrator Replacement
Qué necesitas
  1. Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
    LG A275 Vibrator Replacement, Battery: paso 1, imagen 1 de 2 LG A275 Vibrator Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. LG A275 Vibrator Replacement, Remove cover: paso 2, imagen 1 de 2 LG A275 Vibrator Replacement, Remove cover: paso 2, imagen 2 de 2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. LG A275 Vibrator Replacement: paso 3, imagen 1 de 1
    • Gently remove the battery from the device.
  4. LG A275 Vibrator Replacement, Vibrator: paso 4, imagen 1 de 3 LG A275 Vibrator Replacement, Vibrator: paso 4, imagen 2 de 3 LG A275 Vibrator Replacement, Vibrator: paso 4, imagen 3 de 3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the plastic opening tool not to brute force the phone open, the plastics are fragile.
  5. LG A275 Vibrator Replacement: paso 5, imagen 1 de 2 LG A275 Vibrator Replacement: paso 5, imagen 2 de 2
    • After separating the two plastic halves of the phone, take the plastic that does not have the motherboard attached to it. The plastic has a small yellow component with a lob-sided magnet within it. This is the vibrator of the phone, pull this piece out with your hand. This piece is free floating and will simply drop out.
Conclusión
To reassemble your device, follow these instructions in reverse order after placing in the new vibrator.
Nathanael Knight
Miembro Desde 03/27/18
181 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Spring 2018 Miembro de IUPUI, Team S3-G1, Harley Spring 2018
IUPUI-HARLEY-S18S3G1
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 125
