Introducción
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the speaker in the device.
Qué necesitas
Pry open the back case on the device with a plastic opening tool and remove it.
Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
Insert plastic opening tool under the plastic flap and lift the speaker out.
Una persona más ha completado esta guía.
