Saltar al contenido principal
LG 305C Motherboard Replacement
Qué necesitas
  1. LG 305C Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Motherboard Replacement: paso 2, imagen 1 de 1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Motherboard Replacement, MicroSD card: paso 3, imagen 1 de 1
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
  4. LG 305C Motherboard Replacement, Internal Casing: paso 4, imagen 1 de 1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  5. LG 305C Motherboard Replacement: paso 5, imagen 1 de 1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  6. LG 305C Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  7. LG 305C Motherboard Replacement: paso 7, imagen 1 de 1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  8. LG 305C Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Pry the screen from the internal circuit board with a plastic opening tool and remove it.
Conclusión
Ashley Kidwell
Miembro Desde 03/20/18
427 Reputación
5 Guías creadas
Equipo
IUPUI, Team S6-G1, Baechle Spring 2018 Miembro de IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 146
