Saltar al contenido principal
LG 305C Internal Casing Replacement
Qué necesitas
  1. LG 305C Internal Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Internal Casing Replacement: paso 2, imagen 1 de 1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Internal Casing Replacement, Internal Casing: paso 3, imagen 1 de 1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Internal Casing Replacement: paso 4, imagen 1 de 1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Internal Casing Replacement: paso 5, imagen 1 de 1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Internal Casing Replacement: paso 6, imagen 1 de 1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
Conclusión
Ashley Kidwell
Miembro Desde 03/20/18
427 Reputación
5 Guías creadas
Equipo
IUPUI, Team S6-G1, Baechle Spring 2018 Miembro de IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 119
