Saltar al contenido principal
LG 1010 LCD Screen Replacement
Qué necesitas
  1. LG 1010 LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: paso 2, imagen 1 de 2 LG 1010 LCD Screen Replacement: paso 2, imagen 2 de 2
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: paso 3, imagen 1 de 3 LG 1010 LCD Screen Replacement: paso 3, imagen 2 de 3 LG 1010 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: paso 4, imagen 1 de 2 LG 1010 LCD Screen Replacement, Front  Cover: paso 4, imagen 2 de 2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: paso 6, imagen 1 de 2 LG 1010 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: paso 9, imagen 1 de 1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: paso 10, imagen 1 de 2 LG 1010 LCD Screen Replacement, Back Cover: paso 10, imagen 2 de 2
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: paso 11, imagen 1 de 2 LG 1010 LCD Screen Replacement: paso 11, imagen 2 de 2
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: paso 12, imagen 1 de 1
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: paso 13, imagen 1 de 1
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: paso 14, imagen 1 de 1
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: paso 15, imagen 1 de 2 LG 1010 LCD Screen Replacement: paso 15, imagen 2 de 2
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: paso 16, imagen 1 de 2 LG 1010 LCD Screen Replacement: paso 16, imagen 2 de 2
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-25, Regan Fall 2010 Miembro de Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 961
