Saltar al contenido principal
LG 1010 Front Cover Replacement
Qué necesitas
  1. LG 1010 Front Cover Replacement, Front  Cover: paso 1, imagen 1 de 2 LG 1010 Front Cover Replacement, Front  Cover: paso 1, imagen 2 de 2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: paso 2, imagen 1 de 1
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: paso 3, imagen 1 de 2 LG 1010 Front Cover Replacement: paso 3, imagen 2 de 2
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: paso 4, imagen 1 de 1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: paso 5, imagen 1 de 1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: paso 6, imagen 1 de 1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 3-25, Regan Fall 2010 Miembro de Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,001
