Saltar al contenido principal
LCD X2gen Display disassembly
Qué necesitas
  1. LCD X2gen Display disassembly, LCD X2gen Display disassembly: paso 1, imagen 1 de 1
    • X2gen 22 lcd Screen repair guide
  2. LCD X2gen Display disassembly: paso 2, imagen 1 de 1
    • Power board displaying the capacitors to be replaced
  3. LCD X2gen Display disassembly: paso 3, imagen 1 de 1
    • Display viewed laying face down on the working table (my dining table)
    • Remove the 6 screws. 4 on the corners and 2 middle bottom.
  4. LCD X2gen Display disassembly: paso 4, imagen 1 de 1
    • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
  5. LCD X2gen Display disassembly: paso 5, imagen 1 de 1
    • Top middle
  6. LCD X2gen Display disassembly: paso 6, imagen 1 de 1
    • Front bezel removed.
    • Observe: the control board, bottom right.
    • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
  7. LCD X2gen Display disassembly: paso 7, imagen 1 de 1
    • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
    • This pic shows the right side
  8. LCD X2gen Display disassembly: paso 8, imagen 1 de 1
    • This pic shows the left side
  9. LCD X2gen Display disassembly: paso 9, imagen 1 de 2 LCD X2gen Display disassembly: paso 9, imagen 2 de 2
    • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
    • Slide the monitor to the left about 3-4 inch. to have access to the connections.
  10. LCD X2gen Display disassembly: paso 10, imagen 1 de 1
    • Carefully, unplug both connectors
  11. LCD X2gen Display disassembly: paso 11, imagen 1 de 2 LCD X2gen Display disassembly: paso 11, imagen 2 de 2
    • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
  12. LCD X2gen Display disassembly: paso 12, imagen 1 de 1
    • Remove the data connector and ground.
    • Lift display. Is now completely free
Conclusión
2 personas más completaron esta guía.
Aleks
Miembro Desde 02/11/14
201 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,091
