Introducción
To isolate the LCD screen, one needs to be gentle with separating parts and removing screws from the camera.
Partes
No se requieren partes.
  1. Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
    • Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
  2. Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
    • Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
    • To get to the second screw, rotate the screen.
    • Gently peel off the front and back cover of the screen.
    • Peel back the plastic cover.
    • Gently pull off the screen from the base.
    • A small metal piece between the screen cover and the screen may fall out during repair. Remember to replace it with the rounded corners facing away from the screen during reassembly.
    • This takes a little force.
    • Unplug the wires that are attaching the screen to the circuit board.
Conclusión
3 personas más completaron esta guía.
konrad
Miembro Desde 11/01/11
217 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-31, Regan Winter 2011 Miembro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Miembros
6 Guías creadas
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 12
Todo El Tiempo: 3,334
