Introducción
If the phone has trouble reading your touch input to its touch screen, the digitizer may be damaged or broken. If that is the case, a replacement is in order. This guide will instruct you on how to safely take apart the device to change out the digitizer.
Qué necesitas
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
2 personas más completaron esta guía.
