Saltar al contenido principal
Kyocera Marbl K127 Headphone Jack Replacement
Qué necesitas
  1. Kyocera Marbl K127 Headphone Jack Replacement, Remove the cover on the back of the phone.: paso 1, imagen 1 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the cover on the back of the phone.: paso 1, imagen 2 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the cover on the back of the phone.: paso 1, imagen 3 de 3
    • Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
  2. Kyocera Marbl K127 Headphone Jack Replacement, Remove the battery: paso 2, imagen 1 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the battery: paso 2, imagen 2 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the battery: paso 2, imagen 3 de 3
    • Use your index finger at the top of the battery and pull it towards your body.
  3. Kyocera Marbl K127 Headphone Jack Replacement, Remove the phone backing.: paso 3, imagen 1 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the phone backing.: paso 3, imagen 2 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the phone backing.: paso 3, imagen 3 de 3
    • Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard.
  4. Kyocera Marbl K127 Headphone Jack Replacement, Remove existing headphone jack.: paso 4, imagen 1 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove existing headphone jack.: paso 4, imagen 2 de 3 Kyocera Marbl K127 Headphone Jack Replacement, Remove existing headphone jack.: paso 4, imagen 3 de 3
    • Locate the headphone jack attached to the top right of the motherboard and pull it off using your thumb and index fingers.
Conclusión
Brittany Mitchell
Miembro Desde 09/02/14
309 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 448
