Saltar al contenido principal
Kyocera Hydro Vibe SIM Card Replacement
Qué necesitas
  1. Kyocera Hydro Vibe SIM Card Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe SIM Card Replacement: paso 2, imagen 1 de 3 Kyocera Hydro Vibe SIM Card Replacement: paso 2, imagen 2 de 3 Kyocera Hydro Vibe SIM Card Replacement: paso 2, imagen 3 de 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe SIM Card Replacement, SIM Card: paso 3, imagen 1 de 1
    • Locate the SIM card indicated by the arrows and picture.
  4. Kyocera Hydro Vibe SIM Card Replacement: paso 4, imagen 1 de 2 Kyocera Hydro Vibe SIM Card Replacement: paso 4, imagen 2 de 2
    • Use the precision tweezer set to safely remove the SIM card.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 627
