Introducción
In this guide you will learn how to replace the speaker on the Kyocera Hydro Vibe. You will want to replace the speaker when the phone no longer produces sound. To replace the speaker you will first want to order a new speaker. You will then need a spudger and Phillips #000 screwdriver. The repair will take approximately an hour to complete. There are no foreseen hazards. However, you will want to be careful when taking apart the phone as to not damage it.
Qué necesitas
Remove the back plate of the device by popping it off with your fingernail or a spudger.
