Saltar al contenido principal
Kyocera Hydro Vibe Internal Speaker Replacement
Qué necesitas
  1. Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: paso 1, imagen 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: paso 1, imagen 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: paso 1, imagen 3 de 3
    • Remove the back plate of the device by popping it off with your fingernail or a spudger.
  2. Kyocera Hydro Vibe Internal Speaker Replacement: paso 2, imagen 1 de 2 Kyocera Hydro Vibe Internal Speaker Replacement: paso 2, imagen 2 de 2
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  3. Kyocera Hydro Vibe Internal Speaker Replacement: paso 3, imagen 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: paso 3, imagen 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the trim around the outside of the device by peeling it off with your hands.
  4. Kyocera Hydro Vibe Internal Speaker Replacement: paso 4, imagen 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: paso 4, imagen 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: paso 4, imagen 3 de 3
    • Remove battery using the spudger or your fingernails to pry the battery up out of the case.
  5. Kyocera Hydro Vibe Internal Speaker Replacement: paso 5, imagen 1 de 2 Kyocera Hydro Vibe Internal Speaker Replacement: paso 5, imagen 2 de 2
    • Now remove the rear frame, exposing the speaker. To remove the frame you can use the Spudger tool from the iFixit Tool kit or your hands.
  6. Kyocera Hydro Vibe Internal Speaker Replacement: paso 6, imagen 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: paso 6, imagen 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the speaker from its location on the back frame using a spudger.
Conclusión
Ben Lange
Miembro Desde 11/01/18
139 Reputación
1 Guía escrita
Equipo
IUPUI, Team S3-G6, Harley Fall 2018 Miembro de IUPUI, Team S3-G6, Harley Fall 2018
IUPUI-HARLEY-F18S3G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 210
