Introducción
Remove the camera button and replace it.
Qué necesitas
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
Now that you have taken apart the trim, the camera button should be easily removable.
Locate the camera button. When looking at the back side (battery side), the camera button will be on the left side.
Take the camera button out with tweezers.
