Saltar al contenido principal
Kyocera Hydro Vibe Battery Replacement
Qué necesitas
  1. Kyocera Hydro Vibe Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Battery Replacement: paso 2, imagen 1 de 3 Kyocera Hydro Vibe Battery Replacement: paso 2, imagen 2 de 3 Kyocera Hydro Vibe Battery Replacement: paso 2, imagen 3 de 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,551
