Saltar al contenido principal
Kyocera Hydro Life Charging Port Replacement
Qué necesitas
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: paso 1, imagen 1 de 2 Kyocera Hydro Life Charging Port Replacement, Charging Port: paso 1, imagen 2 de 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: paso 2, imagen 1 de 3 Kyocera Hydro Life Charging Port Replacement: paso 2, imagen 2 de 3 Kyocera Hydro Life Charging Port Replacement: paso 2, imagen 3 de 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: paso 3, imagen 1 de 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: paso 4, imagen 1 de 3 Kyocera Hydro Life Charging Port Replacement: paso 4, imagen 2 de 3 Kyocera Hydro Life Charging Port Replacement: paso 4, imagen 3 de 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: paso 5, imagen 1 de 3 Kyocera Hydro Life Charging Port Replacement: paso 5, imagen 2 de 3 Kyocera Hydro Life Charging Port Replacement: paso 5, imagen 3 de 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: paso 6, imagen 1 de 2 Kyocera Hydro Life Charging Port Replacement: paso 6, imagen 2 de 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: paso 7, imagen 1 de 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: paso 8, imagen 1 de 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: paso 9, imagen 1 de 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: paso 10, imagen 1 de 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 1,022
