Introducción
In this guide you will open up your phone and replace a broken ear piece speaker. In order to insert a new speaker, you will need access to soldering tools and knowledge.
Qué necesitas
Locate the small notch on the bottom right side of the phone.
To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
Pry the back assembly away from the body on all four sides of the phone.
Start prying at the top and work around.
Remove the buttons for the volume and power-this will allow for easier disassembly.
Start by un-attaching the small olive colored chip from the plastic casing.
The chip is connected to the phone by a small orange wire. Keep the wire connected to the chip and the phone body while removing the chip from the black plastic casing.
Pry underneath the chip with the plastic opener until it pops off. Leave the orange wires attached.
2 personas más completaron esta guía.
