Saltar al contenido principal
Kyocera Echo Front Screen Replacement
Qué necesitas
  1. Kyocera Echo Front Screen Replacement, Front Screen: paso 1, imagen 1 de 2 Kyocera Echo Front Screen Replacement, Front Screen: paso 1, imagen 2 de 2
    • Orient the phone so that the screen is facing up. Place the metal spudger in the half-circle opening located near the bottom right of the Sprint logo at the top of the screen, identified with a red square.
  2. Kyocera Echo Front Screen Replacement: paso 2, imagen 1 de 1
    • Gently wedge the metal spudger between the top screen and the phone to separate it. Continue wedging along the outside of the screen carefully with the metal spudger until the screen is apart.
Conclusión
Alex Kinstedt
Miembro Desde 11/05/18
483 Reputación
4 Guías creadas
Equipo
IUPUI, Team S2-G6, Baechle Fall 2018 Miembro de IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 177
