Saltar al contenido principal
Kyocera Echo Flash and Motherboard Replacement
Qué necesitas
  1. Kyocera Echo Flash and Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Flash and Motherboard Replacement: paso 2, imagen 1 de 1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Flash and Motherboard Replacement: paso 3, imagen 1 de 1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Flash and Motherboard Replacement, Flash and Motherboard: paso 4, imagen 1 de 1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Flash and Motherboard Replacement: paso 5, imagen 1 de 1
    • Unscrew 2 Y1000 4.8 mm screws.
  6. Kyocera Echo Flash and Motherboard Replacement: paso 6, imagen 1 de 2 Kyocera Echo Flash and Motherboard Replacement: paso 6, imagen 2 de 2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Flash and Motherboard Replacement: paso 7, imagen 1 de 1
    • Wedge a plastic opening tool under the motherboard directly above the flash. Additionally, use a plastic opening tool to unhook corner labeled in a red square.
  8. Kyocera Echo Flash and Motherboard Replacement: paso 8, imagen 1 de 2 Kyocera Echo Flash and Motherboard Replacement: paso 8, imagen 2 de 2
    • Gently pull the motherboard out of its compartment.
Conclusión
Alex Kinstedt
Miembro Desde 11/05/18
483 Reputación
4 Guías creadas
Equipo
IUPUI, Team S2-G6, Baechle Fall 2018 Miembro de IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 194
