Saltar al contenido principal
Kyocera DuraForce Pro Headphone Jack Replacement
Qué necesitas
  1. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: paso 1, imagen 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: paso 1, imagen 3 de 3
    • Flip the phone on its side so that the volume button is facing up.
    • Use the plastic opening tool to remove outer case of the phone.
    • Remove the 8 screws around the outer portion of the phone with a JIS #0 screwdriver.
  2. Kyocera DuraForce Pro Headphone Jack Replacement: paso 2, imagen 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: paso 2, imagen 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: paso 2, imagen 3 de 3
    • Remove the 2 screws with the same screwdriver bit.
    • Remove battery from the phone with plastic opening tool.
  3. Kyocera DuraForce Pro Headphone Jack Replacement: paso 3, imagen 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: paso 3, imagen 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Once the battery pops out, use tweezers to gently pull the ribbon out along with it.
    • Remove the 2 screws along the sides of the mounting bracket, then remove the bracket.
  4. Kyocera DuraForce Pro Headphone Jack Replacement: paso 4, imagen 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: paso 4, imagen 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: paso 4, imagen 3 de 3
    • Remove final ribbon cable, lift the latch up, and then slide it down. The audio jack will then slide out.
Conclusión
Una persona más ha completado esta guía.
Dylan Ulbricht
Miembro Desde 10/08/18
735 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,330
