Saltar al contenido principal
Kyocera DuraForce Pro Camera Replacement
Qué necesitas
  1. Kyocera DuraForce Pro Camera Replacement, Camera: paso 1, imagen 1 de 3 Kyocera DuraForce Pro Camera Replacement, Camera: paso 1, imagen 2 de 3 Kyocera DuraForce Pro Camera Replacement, Camera: paso 1, imagen 3 de 3
    • Begin with the phone on its side.
    • Use the plastic opening tool to remove the cover. It is easier to begin near the volume button. The cover should pop off on its own.
  2. Kyocera DuraForce Pro Camera Replacement: paso 2, imagen 1 de 3 Kyocera DuraForce Pro Camera Replacement: paso 2, imagen 2 de 3 Kyocera DuraForce Pro Camera Replacement: paso 2, imagen 3 de 3
    • Remove the 8 screws around the outer portion of the phone with the JIS #0 screwdriver bit.
    • Use the plastic opening tool to remove the backside of the phone.
    • Slide the plastic opening tool under the battery to pry it up and remove it.
  3. Kyocera DuraForce Pro Camera Replacement: paso 3, imagen 1 de 3 Kyocera DuraForce Pro Camera Replacement: paso 3, imagen 2 de 3 Kyocera DuraForce Pro Camera Replacement: paso 3, imagen 3 de 3
    • Once the battery pops out, remove the orange tape that connects the battery to the phone.
    • Next, remove the 2 screws connecting the mounting bracket.
    • Remove mounting bracket.
  4. Kyocera DuraForce Pro Camera Replacement: paso 4, imagen 1 de 2 Kyocera DuraForce Pro Camera Replacement: paso 4, imagen 2 de 2
    • Pull the camera housing out of the phone.
Conclusión
Dylan Ulbricht
Miembro Desde 10/08/18
735 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 1,811
