1. Make sure to power down phone before starting. Insert the opening pick/tool into the slit between the case and the body of the phone.  It can be easier to insert near buttons.  Make your way around the case as you use the pick/tool to lift the cover from the body. Once completely loose lift the cover off and set aside.
    • Make sure to power down phone before starting.
    • Insert the opening pick/tool into the slit between the case and the body of the phone. It can be easier to insert near buttons. Make your way around the case as you use the pick/tool to lift the cover from the body.
    • Once completely loose lift the cover off and set aside.
    • This is a good opportunity to blow out any dust that has accumulated.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Using your Phillips 000 remove the eight screws found in the waterproof cover. Make sure to keep your screws in a small bowl or cup to keep them from rolling off the table. Once the screws are removed, take your pick tool and make your way around the case as you use the pick/tool to lift the waterproof cover from the body.
    • Using your Phillips 000 remove the eight screws found in the waterproof cover.
    • Make sure to keep your screws in a small bowl or cup to keep them from rolling off the table.
    • Once the screws are removed, take your pick tool and make your way around the case as you use the pick/tool to lift the waterproof cover from the body.
    • Once loosen by the pick carefully remove the cover from the base and set aside.
    • Be careful of the buttons and port covers that will loosen and come off. If they come completely off set them aside and remember which location/direction they go.
    • Also be careful of the orange seal that is embedded in the waterproof cover. If it comes loose you can push back in place with tweezers.
  4. Highly recommend making sure you are grounded before removing the battery.  You will be handling areas that could cause damage if you accidentally create a static discharge. You will notice a disclaimer on the battery that states that if you remove the battery you void the warranty.  Make sure your warranty has expired  before performing this repair. Starting near the lower area of the phone, carefully press the battery towards the top of the phone and then lift up.
    • Highly recommend making sure you are grounded before removing the battery. You will be handling areas that could cause damage if you accidentally create a static discharge.
    • You will notice a disclaimer on the battery that states that if you remove the battery you void the warranty. Make sure your warranty has expired before performing this repair.
    • Starting near the lower area of the phone, carefully press the battery towards the top of the phone and then lift up.
    • Lift the battery up and over the top of the phone to expose the battery cable and port.
    • Using tweezers and opening tool, flip the lock on the port and carefully pull out the cable.
Conclusión
3 personas más completaron esta guía.
Mike Rote
Miembro Desde 01/02/18
167 Reputación
1 Guía escrita
As of June 2018 there is no new SCP-67LBPS , battery replacement available for the pro.. only used batteries from cannibalized phones.
for anyone interested here is a video of df pro battery removal
https://youtu.be/gz53p6mkAHA
freewillieklr - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 11
Últimos 7 Días: 82
Últimos 30 Días: 315
Todo El Tiempo: 2,783
