Saltar al contenido principal
Kwikset 450248 Battery Replacement
Qué necesitas
  1. Kwikset 450248 Battery Replacement, Battery: paso 1, imagen 1 de 2 Kwikset 450248 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure you are changing the batteries on this model of the Kwikset digital door lock.
    • Prepare your AA batteries and flat head screwdriver before changing the battery.
  2. Kwikset 450248 Battery Replacement: paso 2, imagen 1 de 3 Kwikset 450248 Battery Replacement: paso 2, imagen 2 de 3 Kwikset 450248 Battery Replacement: paso 2, imagen 3 de 3
    • Use your flathead screwdriver to pry your Kwikset door lock cover open.
    • Push up on the cover.
    • Slide the cover up to display the battery storage area.
  3. Kwikset 450248 Battery Replacement: paso 3, imagen 1 de 2 Kwikset 450248 Battery Replacement: paso 3, imagen 2 de 2
    • Grab the top of the battery storage area.
    • Pull the battery storage area out of the device.
  4. Kwikset 450248 Battery Replacement: paso 4, imagen 1 de 2 Kwikset 450248 Battery Replacement: paso 4, imagen 2 de 2
    • Remove all four batteries from the battery storage area.
    • Open the battery package and take four batteries out.
    • Place the new batteries into the battery storage area.
  5. Kwikset 450248 Battery Replacement: paso 5, imagen 1 de 1
    • Put the battery storage device back into the Kwikset door lock.
    • Ensure the yellow label is facing you.
  6. Kwikset 450248 Battery Replacement: paso 6, imagen 1 de 1
    • Slide the cover back onto the Kwikset digital door lock.
Conclusión
To ensure that the Kwikset digital door lock is reassembled properly turn the lock, and listen for the door lock to state door locked or door unlocked.
Taylor S. Matthews
Miembro Desde 09/28/21
133 Reputación
1 Guía escrita
Equipo
UNT-Martin-F23S1G14 Miembro de UNT-Martin-F23S1G14
Community
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 18
Ultimos 30 días: 76
Todo El Tiempo: 281
