Introducción
If the touch screen on your Kurio Xtreme is cracked or broken, follow this guide to replace it.
Qué necesitas
Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
Carefully lift the back panel off of the rest of the device.
Herramienta utilizada en este paso:Plastic Cards$2.99
Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
Carefully lift the battery out of the device and set it aside.
3 personas más completaron esta guía.
2 comentarios
Thanks - very good guide! For the investment of an iFixit toolset and less than 10 GBP for a replacement digitizer, I was able to restore my little boy's treasure!
