Saltar al contenido principal
Kurio Xtreme Power/Volume Buttons Replacement
Qué necesitas
  1. Kurio Xtreme Power/Volume Buttons Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Power/Volume Buttons Replacement: paso 2, imagen 1 de 2 Kurio Xtreme Power/Volume Buttons Replacement: paso 2, imagen 2 de 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Power/Volume Buttons Replacement: paso 3, imagen 1 de 3 Kurio Xtreme Power/Volume Buttons Replacement: paso 3, imagen 2 de 3 Kurio Xtreme Power/Volume Buttons Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Power/Volume Buttons Replacement, Power/Volume Buttons: paso 4, imagen 1 de 1
    • Remove the three 4 mm screws on the motherboard with a Phillips #000 screwdriver.
  5. Kurio Xtreme Power/Volume Buttons Replacement: paso 5, imagen 1 de 2 Kurio Xtreme Power/Volume Buttons Replacement: paso 5, imagen 2 de 2
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
  6. Kurio Xtreme Power/Volume Buttons Replacement: paso 6, imagen 1 de 2 Kurio Xtreme Power/Volume Buttons Replacement: paso 6, imagen 2 de 2
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
  7. Kurio Xtreme Power/Volume Buttons Replacement: paso 7, imagen 1 de 1
    • Remove the speakers out of the plastic molds by lifting up the black and red wires.
    • Be careful not to disconnect the black and red wires from the motherboard.
  8. Kurio Xtreme Power/Volume Buttons Replacement: paso 8, imagen 1 de 2 Kurio Xtreme Power/Volume Buttons Replacement: paso 8, imagen 2 de 2
    • Remove the motherboard by lifting it out of the casing. Set it upside down below the casing.
    • The motherboard will still be connected to the battery and the speakers.
  9. Kurio Xtreme Power/Volume Buttons Replacement: paso 9, imagen 1 de 3 Kurio Xtreme Power/Volume Buttons Replacement: paso 9, imagen 2 de 3 Kurio Xtreme Power/Volume Buttons Replacement: paso 9, imagen 3 de 3
    • Remove the volume buttons and/or power button by soldering them at their bases.
    • Volume down
    • Volume up
    • Power
Conclusión
Una persona más ha completado esta guía.
Mallory Myers
Miembro Desde 09/22/15
1,190 Reputación
7 Guías creadas
Equipo
Baylor, Team 6-10, Williams Fall 2015 Miembro de Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 891
