Saltar al contenido principal
Kurio Xtreme Camera Replacement
Qué necesitas
  1. Kurio Xtreme Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Camera Replacement: paso 2, imagen 1 de 2 Kurio Xtreme Camera Replacement: paso 2, imagen 2 de 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Camera Replacement: paso 3, imagen 1 de 3 Kurio Xtreme Camera Replacement: paso 3, imagen 2 de 3 Kurio Xtreme Camera Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Camera Replacement, Camera: paso 4, imagen 1 de 1
    • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
  5. Kurio Xtreme Camera Replacement: paso 5, imagen 1 de 3 Kurio Xtreme Camera Replacement: paso 5, imagen 2 de 3 Kurio Xtreme Camera Replacement: paso 5, imagen 3 de 3
    • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
    • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
Conclusión
Una persona más ha completado esta guía.
Mallory Myers
Miembro Desde 09/22/15
1,190 Reputación
7 Guías creadas
Equipo
Baylor, Team 6-10, Williams Fall 2015 Miembro de Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 175
