Saltar al contenido principal
Kurio Touch 4S Speaker Replacement
Qué necesitas
  1. Kurio Touch 4S Speaker  Replacement, Speakers: paso 1, imagen 1 de 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: paso 2, imagen 1 de 3 Kurio Touch 4S Speaker  Replacement: paso 2, imagen 2 de 3 Kurio Touch 4S Speaker  Replacement: paso 2, imagen 3 de 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: paso 3, imagen 1 de 2 Kurio Touch 4S Speaker  Replacement: paso 3, imagen 2 de 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: paso 4, imagen 1 de 1
  5. Kurio Touch 4S Speaker  Replacement: paso 5, imagen 1 de 1
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: paso 6, imagen 1 de 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: paso 7, imagen 1 de 1
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: paso 8, imagen 1 de 1
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
Conclusión
Una persona más ha completado esta guía.
Moin Khan
Miembro Desde 01/21/15
234 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-5, Brown Winter 2015 Miembro de USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 171
