Saltar al contenido principal
Kurio Touch 4S Power Button Replacement
Qué necesitas
  1. Kurio Touch 4S Power Button Replacement, Power Button: paso 1, imagen 1 de 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Power Button Replacement: paso 2, imagen 1 de 3 Kurio Touch 4S Power Button Replacement: paso 2, imagen 2 de 3 Kurio Touch 4S Power Button Replacement: paso 2, imagen 3 de 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Power Button Replacement: paso 3, imagen 1 de 2 Kurio Touch 4S Power Button Replacement: paso 3, imagen 2 de 2
    • To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Power Button Replacement: paso 4, imagen 1 de 1
    • After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Power Button Replacement: paso 5, imagen 1 de 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  6. Kurio Touch 4S Power Button Replacement: paso 6, imagen 1 de 1
    • Gently remove the plastic cover that is covering the camera.
  7. Kurio Touch 4S Power Button Replacement: paso 7, imagen 1 de 1
    • Use Phillips # 1 screw to open the four 5mm Philips screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Power Button Replacement: paso 8, imagen 1 de 1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Power Button Replacement: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Power Button Replacement: paso 10, imagen 1 de 2 Kurio Touch 4S Power Button Replacement: paso 10, imagen 2 de 2
    • Detach all the wire that are connected to the motherboard.
    • Detach the camera module and other components that are attached to the motherboard.
  11. Kurio Touch 4S Power Button Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Power Button Replacement: paso 12, imagen 1 de 1
    • Use tweezers to hold the power button and gently lift it up.
    • Replace the old power button with the new one.
Conclusión
Una persona más ha completado esta guía.
Moin Khan
Miembro Desde 01/21/15
234 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-5, Brown Winter 2015 Miembro de USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 473
