Saltar al contenido principal
Kurio Motion Audio Jack Replacement
Qué necesitas
  1. Kurio Motion Audio Jack Replacement, Audio Jack: paso 1, imagen 1 de 2 Kurio Motion Audio Jack Replacement, Audio Jack: paso 1, imagen 2 de 2
    • Use a Phillips #00 Screwdriver to unscrew the four 5mm screws.
  2. Kurio Motion Audio Jack Replacement: paso 2, imagen 1 de 1
    • Use an Ifixit opening tool to seperate the screen from the back.
    • The screen is connected to the back by tabs on the inside of the device. If you pry too hard, they may break.
  3. Kurio Motion Audio Jack Replacement: paso 3, imagen 1 de 1
    • Remove the tape from the edges of the battery and the small piece on the motherboard.
  4. Kurio Motion Audio Jack Replacement: paso 4, imagen 1 de 2 Kurio Motion Audio Jack Replacement: paso 4, imagen 2 de 2
    • Remove the two 5mm screws from the mother board.
    • Remove the connectors by lifting the tabs and pulling gently.
    • Desolder the connections holding the audio jack. To do so, refer to this guide.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 12
