Saltar al contenido principal
Krups F203 Coffee Grinder Trigger Assembly Replacement
Qué necesitas
  1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Base Plate: paso 1, imagen 1 de 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 2, imagen 1 de 3 Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 2, imagen 2 de 3 Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 2, imagen 3 de 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 3, imagen 1 de 2 Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 3, imagen 2 de 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Trigger Assembly Replacement, Detach Trigger Button from Base Plate: paso 4, imagen 1 de 1
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 5, imagen 1 de 2 Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 5, imagen 2 de 2
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Trigger Assembly Replacement: paso 6, imagen 1 de 1
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
Conclusión
2 personas más completaron esta guía.
Ian Hancock
Miembro Desde 10/22/14
414 Reputación
3 Guías creadas
Equipo
Baylor, Team 4-2, Williams Fall 2014 Miembro de Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 5,417
