Saltar al contenido principal
Krups F203 Coffee Grinder Base Plate Replacement
Qué necesitas
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: paso 1, imagen 1 de 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: paso 2, imagen 1 de 3 Krups F203 Coffee Grinder Base Plate Replacement: paso 2, imagen 2 de 3 Krups F203 Coffee Grinder Base Plate Replacement: paso 2, imagen 3 de 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: paso 3, imagen 1 de 2 Krups F203 Coffee Grinder Base Plate Replacement: paso 3, imagen 2 de 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
Conclusión
9 personas más completaron esta guía.
Equipo
Baylor, Team 4-2, Williams Fall 2014 Miembro de Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Miembros
8 Guías creadas
10 comentarios
Thanks! I was able to repair my broken cord.
wdswaim - Contestar
I'mworking on it as we write .
jerry - Contestar
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - Contestar
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - Contestar
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 54
Todo El Tiempo: 11,264
