Saltar al contenido principal
Krups 963 Power Switch Replacement
Qué necesitas
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: paso 1, imagen 1 de 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: paso 2, imagen 1 de 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: paso 3, imagen 1 de 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: paso 4, imagen 1 de 1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: paso 5, imagen 1 de 1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Conclusión
Wyatt Hall
Miembro Desde 10/13/14
842 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 6-25, Maness Fall 2014 Miembro de Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Miembros
7 Guías creadas
Un comentario
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 3,048
