Saltar al contenido principal
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: paso 1, imagen 1 de 2 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: paso 1, imagen 2 de 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: paso 2, imagen 1 de 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
Conclusión
Hieu Ngo
Miembro Desde 03/22/17
431 Reputación
4 Guías creadas
Equipo
Un comentario
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 1,008
