Saltar al contenido principal
Kolcraft Cloud Plus "Free-Stand" Button Replacement
Qué necesitas
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: paso 1, imagen 1 de 2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: paso 1, imagen 2 de 2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: paso 2, imagen 1 de 1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: paso 3, imagen 1 de 1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: paso 4, imagen 1 de 1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Conclusión
Equipo
Cal Poly, Team 11-1, Forte Fall 2015 Miembro de Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 1,273
