Saltar al contenido principal
Kodak Signet 35 Shutter Spring Replacement
Qué necesitas
  1. Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: paso 1, imagen 1 de 3 Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: paso 1, imagen 2 de 3 Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: paso 1, imagen 3 de 3
    • While the camera is lying on its back, unscrew the front lens assembly and remove the lens and the faceplate. Then lift off the speed setting.
  2. Kodak Signet 35 Shutter Spring Replacement: paso 2, imagen 1 de 2 Kodak Signet 35 Shutter Spring Replacement: paso 2, imagen 2 de 2
    • Remove the lever from the stopper by pushing it back and then upwards.
  3. Kodak Signet 35 Shutter Spring Replacement: paso 3, imagen 1 de 2 Kodak Signet 35 Shutter Spring Replacement: paso 3, imagen 2 de 2
    • Remove the stopper by lifting it upwards with the tweezers.
  4. Kodak Signet 35 Shutter Spring Replacement: paso 4, imagen 1 de 3 Kodak Signet 35 Shutter Spring Replacement: paso 4, imagen 2 de 3 Kodak Signet 35 Shutter Spring Replacement: paso 4, imagen 3 de 3
    • Using tweezers, unhitch the spring from the base and remove it by lifting upwards.
Conclusión
Equipo
USF Tampa, Team 6-3, Remmell Fall 2016 Miembro de USF Tampa, Team 6-3, Remmell Fall 2016
USFT-REMMELL-F16S6G3
4 Miembros
9 Guías creadas
2 comentarios
What kind of spring can be used to replace it or how would one revitalize the old spring?
Ben Le - Contestar
What does “front lens assembly” look like? what parts do I have to unscrew?
Shawn Reynolds - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 2,203
