Introducción
If the image is broken or hazy when looking through the viewfinder of your Kodak Signet 35, then the beamsplitter may be broken or dirty. This guide will show you how to remove it for cleaning or replacing. Before following these steps, make sure you have all the necessary tools, as well as enough time to disassemble and reassemble the device with the proper care.
Qué necesitas
Herramienta utilizada en este paso:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using the 2.5mm flathead screwdriver, remove both 2.8mm flathead screws that hold the wind and rewind dials in place. Then, remove the washer located underneath each dial.
Using the Phillips head screwdriver, remove the vertical-facing 2.1mm Phillips #00 screw that holds the metal bracket in place and set it aside.
With the 2.5mm flathead screwdriver, loosen the horizontal-facing 2.1mm flathead screw that holds the metal bracket in place and set it aside.
2 personas más completaron esta guía.
Un comentario
I feel like the beamsplitter's position can change a great deal depending on how lose the arm is and after cleaning/repair it definitely shifts. How does one position it properly?
I just cleaned mine and now I see two triangles at the bottom of the viewfinder (used to see nothing because the glass elements were all very dirty).
