Saltar al contenido principal
Kodak PixPro AZ251 LCD Screen Replacement
Qué necesitas
  1. Kodak PixPro AZ251 LCD Screen Replacement, Batteries: paso 1, imagen 1 de 2 Kodak PixPro AZ251 LCD Screen Replacement, Batteries: paso 1, imagen 2 de 2
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 LCD Screen Replacement: paso 2, imagen 1 de 2 Kodak PixPro AZ251 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the batteries.
  4. Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: paso 4, imagen 1 de 3 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: paso 4, imagen 2 de 3 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: paso 4, imagen 3 de 3
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 LCD Screen Replacement: paso 6, imagen 1 de 2 Kodak PixPro AZ251 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 LCD Screen Replacement: paso 7, imagen 1 de 3 Kodak PixPro AZ251 LCD Screen Replacement: paso 7, imagen 2 de 3 Kodak PixPro AZ251 LCD Screen Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: paso 8, imagen 1 de 2 Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: paso 8, imagen 2 de 2
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 LCD Screen Replacement: paso 9, imagen 1 de 1
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 LCD Screen Replacement: paso 10, imagen 1 de 2 Kodak PixPro AZ251 LCD Screen Replacement: paso 10, imagen 2 de 2
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 LCD Screen Replacement: paso 11, imagen 1 de 2 Kodak PixPro AZ251 LCD Screen Replacement: paso 11, imagen 2 de 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
Conclusión
Equipo
USF Tampa, Team S1-G1, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 37
Todo El Tiempo: 1,584
