Qué necesitas
Open the battery cover and remove the AA batteries from the camera if any are inserted.
Remove all screws on the outside of the camera with a 00 Phillips-Head screwdriver
Eight (8) 3mm screws on the lower portion of the camera
Four (4) screws on the bottom of the camera
Four (4) screws inside the battery cover
Unscrew the four (4) 3mm screws to remove the screen from the circuit board
Use Tweezers to delicately detach the ribbon cable
Carefully remove the screen brace from the circuit board
Use the Tweezers to detach the ribbon cable connecter from the circuit board
Use the Plastic Opening Tool to gently apply pressure on the top of the camera and remove the upper portion
Pull the small brace on top of the shutter button
Using the Tweezers, gently remove the shutter button
