Saltar al contenido principal
Kodak Easyshare Z981 LCD Screen Replacement
Qué necesitas
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Open the battery cover and remove batteries from the camera if any are inserted.
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  2. Kodak Easyshare Z981 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  3. Kodak Easyshare Z981 LCD Screen Replacement: paso 5, imagen 1 de 2 Kodak Easyshare Z981 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  4. Kodak Easyshare Z981 LCD Screen Replacement: paso 6, imagen 1 de 2 Kodak Easyshare Z981 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
    • Gently lift up the metal brace and use a pair to disconnect the ribbon cable connecter
    • Use Tweezers to disconnect the ribbon cable connector.
    • Once disconnected remove the screen brace from the circuit board
    • Use extreme caution when removing the LCD brace pulling the brace may tear the cable
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 560
