Qué necesitas
Open the battery cover and remove batteries from the camera if any are inserted.
Use a 00 Phillips-Head screwdriver to remove screws:
Remove the 3 mm screws from the camera
Four (4) screws are in the bottom of the device
Four (4) screws are inside the battery cover
Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
Two (2) screws are located in the left side of the device
Two (2) screws are locatecd in the right side of the device
Una persona más ha completado esta guía.
