Saltar al contenido principal
Kodak Easyshare Z981 Bottom Panel Replacement
Qué necesitas
  1. Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: paso 1, imagen 1 de 2 Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
    • Use a 00 Phillips-Head screwdriver
    • Remove the 3 mm screws from the camera.
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  2. Kodak Easyshare Z981 Bottom Panel Replacement: paso 3, imagen 1 de 1
    • Start from a corner and gently remove the bottom cover.
    • The cover will easily lift off, so not much pressure is required.
    • Be gentle while removing the cover, to avoid breaking the plastic
  3. Kodak Easyshare Z981 Bottom Panel Replacement: paso 4, imagen 1 de 3 Kodak Easyshare Z981 Bottom Panel Replacement: paso 4, imagen 2 de 3 Kodak Easyshare Z981 Bottom Panel Replacement: paso 4, imagen 3 de 3
    • Remove the bottom of the battery cover first, and then the top.
    • The hinge is simple, the screwdriver is no longer necessary.
Conclusión
5 personas más completaron esta guía.
6 comentarios
where can i buy it?
Lizette Nin - Contestar
PLEASE help? I can't find this part anywhere?
thecarlisles - Contestar
Did anyone ever find the parts to complete this task? It's exactly what I need to do but cant find the bottom plate anywhere.
Billy T - Contestar
I need the bottom panel also. If anyone knows where to purchase it please email me kpw1god@yahoo.com
kpw1god - Contestar
I HAVE THE SAME QUESTION. WHERE  ARE THE PARTS BOUGHT??????? WHY PUT THIS OUT  IF U CAN’T BUY THE PARTS?? bILL     RENTMRBILL@YAHOO.COM
rentmrbill - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 2,154
