Saltar al contenido principal
Kodak Easyshare Z981 Back Cover Replacement
Qué necesitas
  1. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) inside the battery cover
  2. Kodak Easyshare Z981 Back Cover Replacement: paso 2, imagen 1 de 1
    • Start from a corner and gently remove the bottom cover of the camera.
    • The cover will easily lift off without much pressure necessary.
  3. Kodak Easyshare Z981 Back Cover Replacement: paso 3, imagen 1 de 2 Kodak Easyshare Z981 Back Cover Replacement: paso 3, imagen 2 de 2
    $5.49
    Comprar
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  4. Kodak Easyshare Z981 Back Cover Replacement: paso 4, imagen 1 de 2 Kodak Easyshare Z981 Back Cover Replacement: paso 4, imagen 2 de 2
    • Use a Plastic Opening Tool to remove the back of the camera and pull gently on the cover to remove the cover
    • Start from one corner and apply light pressure with the tool.
Conclusión
Una persona más ha completado esta guía.
Olivia Boyna
Miembro Desde 03/03/15
509 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 644
