Saltar al contenido principal
Kodak Easyshare V1003 Lens Replacement
Qué necesitas
  1. Kodak Easyshare V1003 Lens  Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003 Lens  Replacement: paso 2, imagen 1 de 1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003 Lens  Replacement: paso 3, imagen 1 de 1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003 Lens  Replacement: paso 4, imagen 1 de 1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003 Lens  Replacement: paso 5, imagen 1 de 2 Kodak Easyshare V1003 Lens  Replacement: paso 5, imagen 2 de 2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003 Lens  Replacement, Lens: paso 6, imagen 1 de 2 Kodak Easyshare V1003 Lens  Replacement, Lens: paso 6, imagen 2 de 2
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003 Lens  Replacement: paso 7, imagen 1 de 1
    • Pull the outer case off using the plastic opening tool.
  8. Kodak Easyshare V1003 Lens  Replacement: paso 8, imagen 1 de 2 Kodak Easyshare V1003 Lens  Replacement: paso 8, imagen 2 de 2
    • Remove the LCD display by unplugging the connector
    • Take apart the LCD display from the back case
  9. Kodak Easyshare V1003 Lens  Replacement: paso 9, imagen 1 de 2 Kodak Easyshare V1003 Lens  Replacement: paso 9, imagen 2 de 2
    • Peel off the yellow film.
    • Peel off the black tape holding the wires.
  10. Kodak Easyshare V1003 Lens  Replacement: paso 10, imagen 1 de 1
    • Unplug the connector by lifting the little lock holding it in place.
  11. Kodak Easyshare V1003 Lens  Replacement: paso 11, imagen 1 de 2 Kodak Easyshare V1003 Lens  Replacement: paso 11, imagen 2 de 2
    • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
  12. Kodak Easyshare V1003 Lens  Replacement: paso 12, imagen 1 de 3 Kodak Easyshare V1003 Lens  Replacement: paso 12, imagen 2 de 3 Kodak Easyshare V1003 Lens  Replacement: paso 12, imagen 3 de 3
    • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
    • Gently pull out the lens using you finger tips or pincers.
Conclusión
Sarah Berry
Miembro Desde 03/21/17
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 319
