Saltar al contenido principal
Kodak Easyshare V1003 LCD Display Replacement
Qué necesitas
  1. Kodak Easyshare V1003  LCD Display Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003  LCD Display Replacement: paso 2, imagen 1 de 1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003  LCD Display Replacement: paso 3, imagen 1 de 1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003  LCD Display Replacement: paso 4, imagen 1 de 1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003  LCD Display Replacement: paso 5, imagen 1 de 2 Kodak Easyshare V1003  LCD Display Replacement: paso 5, imagen 2 de 2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003  LCD Display Replacement, Buttons: paso 6, imagen 1 de 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: paso 6, imagen 2 de 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: paso 6, imagen 3 de 3
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003  LCD Display Replacement: paso 7, imagen 1 de 3 Kodak Easyshare V1003  LCD Display Replacement: paso 7, imagen 2 de 3 Kodak Easyshare V1003  LCD Display Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to pry off the back casing.
  8. Kodak Easyshare V1003  LCD Display Replacement: paso 8, imagen 1 de 3 Kodak Easyshare V1003  LCD Display Replacement: paso 8, imagen 2 de 3 Kodak Easyshare V1003  LCD Display Replacement: paso 8, imagen 3 de 3
    • Completely remove the back casing from the device.
    • Using a plastic tool to remove the bottom.
  9. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: paso 9, imagen 1 de 1
    • Remove the LCD display by unplugging the connector.
  10. Kodak Easyshare V1003  LCD Display Replacement: paso 10, imagen 1 de 1
    • Take apart the LCD display from the back case.
Conclusión
Una persona más ha completado esta guía.
Vanessa Soares
Miembro Desde 03/15/17
222 Reputación
2 Guías creadas
Equipo
Un comentario
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 715
