Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Kodak Easyshare C813 Shutter Button Replacement
Qué necesitas
    1. Kodak Easyshare C813 Shutter Button Replacement, Battery: paso 1, imagen 1 de 1
      • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
      Pregunta a FixBot
      Agregar Comentario
    2. Kodak Easyshare C813 Shutter Button Replacement: paso 2, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 2, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 2, imagen 3 de 3
      • Press thumb firmly on battery door and slide it in the direction of the arrow.
      • Lift thumb allowing the door to swing open.
      Pregunta a FixBot
      Agregar Comentario
    1. Kodak Easyshare C813 Shutter Button Replacement, Back Cover: paso 3, imagen 1 de 1
      Herramienta utilizada en este paso:
      Anti-Static Wrist Strap
      $7.95
      Pregunta a FixBot
      Agregar Comentario
    2. Kodak Easyshare C813 Shutter Button Replacement: paso 4, imagen 1 de 1
      • Turn the camera off by firmly pressing the power button located on top of the camera.
      Pregunta a FixBot
      Agregar Comentario
    3. Kodak Easyshare C813 Shutter Button Replacement: paso 5, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 5, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 5, imagen 3 de 3
      • Locate the 7 screws holding the back cover on.
      • Three screws are located on the bottom of the camera.
      • Two screws are located on the side shown in the photograph.
      • Two final screws are located on the opposite side shown in the photograph.
      Pregunta a FixBot
      Agregar Comentario
    4. Kodak Easyshare C813 Shutter Button Replacement: paso 6, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 6, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 6, imagen 3 de 3
      • Remove all 7 screws:
      • Hold the camera firmly with one hand so that you can still see a screw.
      • Place the Philips 00(Found here)screwdriver into the screw.
      • Turn the screwdriver to the left until it is free.
      • Repeat for the remaining screws.
      Pregunta a FixBot
      Agregar Comentario
    5. Kodak Easyshare C813 Shutter Button Replacement: paso 7, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 7, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 7, imagen 3 de 3
      • Use plastic opening tools to slightly open the side of the case.
      • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
      • The first two are near the words "3X Optical Zoom".
      • The third is near the shutter button.
      Pregunta a FixBot
      Agregar Comentario
    6. Kodak Easyshare C813 Shutter Button Replacement: paso 8, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 8, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 8, imagen 3 de 3
      • Gently pull apart the back cover from the rest of the camera.
      • Make sure there are no more screws or tabs keeping the cover on.
      • Use the plastic opening tool to separate any sides still closely connected.
      Pregunta a FixBot
      Agregar Comentario
    1. Kodak Easyshare C813 Shutter Button Replacement, Front Cover: paso 9, imagen 1 de 2 Kodak Easyshare C813 Shutter Button Replacement, Front Cover: paso 9, imagen 2 de 2
      • Open the battery door.
      Pregunta a FixBot
      Agregar Comentario
    2. Kodak Easyshare C813 Shutter Button Replacement: paso 10, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 10, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 10, imagen 3 de 3
      • Use the plastic opening tool to lift the casing around the shutter button.
      • Gently remove the front cover from the device.
      Pregunta a FixBot
      Agregar Comentario
    3. Kodak Easyshare C813 Shutter Button Replacement: paso 11, imagen 1 de 1
      • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
      • To discharge the capacitor follow this guide.
      Pregunta a FixBot
      Agregar Comentario
    1. Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: paso 12, imagen 1 de 2 Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: paso 12, imagen 2 de 2
      • The shutter button is held on to the front cover by three screws
      • Hold the shutter button in place
      • Use a Philips 00 screwdriver to remove the screws.
      • Careful that the power and flash button do not fall off
      Pregunta a FixBot
      Agregar Comentario
    2. Kodak Easyshare C813 Shutter Button Replacement: paso 13, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 13, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 13, imagen 3 de 3
      • Keep the shutter button in place while removing the circular metal plate
      • Remove the shutter button by allowing it to fall into your hand
      Pregunta a FixBot
      Agregar Comentario
    3. Kodak Easyshare C813 Shutter Button Replacement: paso 14, imagen 1 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 14, imagen 2 de 3 Kodak Easyshare C813 Shutter Button Replacement: paso 14, imagen 3 de 3
      • Hold down the shutter button portion of the selector dial
      • Press down the red tabs and slowly relieve pressure on the shutter button
      • Press down on the center red stick
      • Careful not to lose the spring
      • Tool shown is Found here
      Pregunta a FixBot
      Agregar Comentario
    4. Kodak Easyshare C813 Shutter Button Replacement: paso 15, imagen 1 de 1
      • If cleaning, remove dirt from button
      • When putting back together, the button should be be oriented so that the green automatic mode points towards the power button.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 24-22, Regan Spring 2010 Miembro de Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
Miembros de 4
32 Guías creadas
1Guía Comentario
does anybody know how the pins works on the surface mounted shutter switch button on the PCB? this would be very helpful thanks!
random - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 46
Todo El Tiempo: 8,531
