Introducción
This guide shows how to replace a broken LCD on a C183. It is not a difficult job, however, most cameras open from the back case first, this one opens from the front first.
Qué necesitas
Remove the two screws from the right hand side
Remove the two screws from the left hand side
Remove the three screws from the bottom.
Open the battery compartment and start carefully to separate the front and back half of the camera. On this camera the front half will come of first.
In the top left corner is one screw that will have to be removed. It holds the back cover to the body of the camera.
Once that screw is removed, the camera separates easy.
