Saltar al contenido principal
Kodak EasyShare Z740 Back Cover Replacement
Qué necesitas
  1. Kodak EasyShare Z740 Back Cover Replacement, Battery: paso 1, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement, Battery: paso 1, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the door on the bottom of the camera in the direction of the open symbol with your finger.
    • Release and the door will pop open.
  2. Kodak EasyShare Z740 Back Cover Replacement: paso 2, imagen 1 de 2 Kodak EasyShare Z740 Back Cover Replacement: paso 2, imagen 2 de 2
    • Slide the battery out.
  3. Kodak EasyShare Z740 Back Cover Replacement, SD/MMC: paso 3, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement, SD/MMC: paso 3, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement, SD/MMC: paso 3, imagen 3 de 3
    • Flip open the door on the right side of the camera, when looking at the LCD screen.
    • This door has a memory card and A/V OUT symbol on it.
  4. Kodak EasyShare Z740 Back Cover Replacement: paso 4, imagen 1 de 2 Kodak EasyShare Z740 Back Cover Replacement: paso 4, imagen 2 de 2
    • Gently push SD/MMC to eject.
  5. Kodak EasyShare Z740 Back Cover Replacement: paso 5, imagen 1 de 2 Kodak EasyShare Z740 Back Cover Replacement: paso 5, imagen 2 de 2
    • Pull SD/MMC out of the camera.
  6. Kodak EasyShare Z740 Back Cover Replacement, Lens Cover: paso 6, imagen 1 de 2 Kodak EasyShare Z740 Back Cover Replacement, Lens Cover: paso 6, imagen 2 de 2
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
  7. Kodak EasyShare Z740 Back Cover Replacement: paso 7, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 7, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 7, imagen 3 de 3
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
  8. Kodak EasyShare Z740 Back Cover Replacement: paso 8, imagen 1 de 2 Kodak EasyShare Z740 Back Cover Replacement: paso 8, imagen 2 de 2
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
  9. Kodak EasyShare Z740 Back Cover Replacement: paso 9, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 9, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 9, imagen 3 de 3
    • Separate the two pieces of the loop and pull the lens cover up in between them.
  10. Kodak EasyShare Z740 Back Cover Replacement: paso 10, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 10, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 10, imagen 3 de 3
    • Pull the lens cover and the sting will come out of the metal slab.
  11. Kodak EasyShare Z740 Back Cover Replacement, Back Cover: paso 11, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement, Back Cover: paso 11, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement, Back Cover: paso 11, imagen 3 de 3
    • Place lens cover back on the lens to prevent scratches or debris but leave string detached.
    • Remove a total of six 3.968mm Phillips #00 screws. Two each from the left side, bottom, and right side.
  12. Kodak EasyShare Z740 Back Cover Replacement: paso 12, imagen 1 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 12, imagen 2 de 3 Kodak EasyShare Z740 Back Cover Replacement: paso 12, imagen 3 de 3
    • Pull the back cover away from the front cover.
    • You may need to use a plastic opening tool as a wedge if it does not come apart by easily.
  13. Kodak EasyShare Z740 Back Cover Replacement: paso 13, imagen 1 de 1
    • Separate the back cover from the front cover.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 947
